Forums >> Revit Systems >> Technical Support >> Turn off automatic select when circuiting?
Tue, Jan 4, 2011 at 7:28:11 PM | Turn off automatic select when circuiting?
cpguy33
When circuiting how do you turn off the function where revit automatically selects all items that are connected with wires when you want to add an item to a circuit. We typically do the wiring without circuiting, and then come back and circuit later. I am running into problems where I have two connectors on a light fixture, one for normal and one for emergency. I have the emergency wires connected to the emergency connector and normal wires connected to the normal connector. When I go to circuit them, or even add a fixture, and I select edit circit and add the fixture to the circuit revit selects all fixtures wired to both the normal and emergency connector. I do not want revit to automatically select anything and I want to be able to add elements individually.
I am using Revit MEP 2011
Revit MEP 2011 crashes when circuiting electrical devices.
Thu, Jan 27, 2011 at 9:27:58 AM
Automatic Beam System and Tag On Options
Wed, Nov 26, 2014 at 7:29:00 PM
Automatic extension gate
Wed, Dec 26, 2012 at 11:56:03 AM
2 and 3 pole circuits in Revet MEP 2011
Thu, May 19, 2011 at 4:15:31 PM
Electrical Circuiting
Fri, Oct 19, 2012 at 6:23:41 PM
Page generation time: 6.6662
