Forums >> Revit Building >> Technical Support >> Room finish schedule question
Wed, Nov 2, 2005 at 5:01:36 PM | Room finish schedule question
bigstein
Hello I am trying to create a room finish schedule that can automatically identify the materials on each wall of a room (North, South, East, West). I tried drawing a room with 2 walls cmu and 2 walls gyp, but it does not recognize them and all I can do is call them out as 'painted' in the schedule. Has anyone dealt with this? Thanks
Wed, Nov 2, 2005 at 5:06:12 PM | RE: Room finish schedule question
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This is what key notes were invented for (if you have lots of rooms that are the same). There is no way to have the wall materials actually link to the room finish schedule. You can add parameters to rooms for each wall and then manually type in the materials for each in the schedule. HTH.
Wed, Nov 2, 2005 at 5:34:52 PM | RE: Room finish schedule question
bigstein
That's what I thought. How hard would that have been to add into the room schedule routine, right? Thanks
Thu, Nov 3, 2005 at 5:24:53 PM | RE: Room finish schedule question
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The difficulty comes from the number of walls that make up the room. It tends to vary. For this reason it wouldn't really be logical to have these parameters unless all your rooms were rectangular. You could easily add these extra project parameters to your template so they are there for all future projects.
Thu, Nov 3, 2005 at 5:27:15 PM | RE: Room finish schedule question
bigstein
Thanks - I see what you mean now about multiple facets.
Wed, Jul 8, 2009 at 3:33:52 PM | Room finish schedule question
Ebramwell
Is this still true now that we are in Revit 2010?
Room finish Schedule showing Deleted Rooms
Wed, Aug 26, 2009 at 3:56:37 PM
Revit 2016 Room finish schedule and material schedule
Thu, Mar 9, 2017 at 3:41:41 PM
Renumbering rooms -- rooms out of numeric order on Room Finish Schedule
Thu, Dec 10, 2015 at 11:01:57 AM
Finish Material Schedule
Tue, Nov 29, 2005 at 12:31:59 PM
Room Schedule: wall finish for each wall in a room
Wed, Dec 19, 2012 at 5:00:38 PM
Page generation time: 4.1652
