Forums >> Revit Building >> Technical Support >> Creating a dimension where one end doesn't dimension to a specific point
Tue, Jan 4, 2011 at 12:51:44 PM | Creating a dimension where one end doesn't dimension to a specific point
kevinb13
I have an issue with the dimensioning in a drafting view.  I am creating a roof detail and am giving it a dimension to tie it to the finished floor line.  I am not showing the floor line, so I want to create a dimension that uses two arrowheads to represent that it is dimensioned to the finished floor line that is not shown...any ideas on how to do this?
I am using Revit Architecture 2011.
Tue, Jan 4, 2011 at 1:07:41 PM | Creating a dimension where one end doesn't dimension to a specific point
Add a line and dimension to that.
Tue, Jan 4, 2011 at 1:55:38 PM | Creating a dimension where one end doesn't dimension to a specific point
kevinb13
Good idea...thanks
The thing is, is there a way to do this without tieing to a second line and also create a second arrowhead on the one side to show that the dimension keeps going beyond the end of the dimension line
Tue, Jan 4, 2011 at 2:11:47 PM | Creating a dimension where one end doesn't dimension to a specific point
Yes... It is called linework and text - not a dimension.  If you want to fake something then fake it!  A dimension is real.
Tue, Jan 4, 2011 at 4:56:36 PM | Creating a dimension where one end doesn't dimension to a specific point
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
As an alternative, you can use a line based detail component...just be careful that you don't start using it inlieu of the dimension command.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Dimension String Doesn't Equal Overall Dimension
Wed, May 27, 2009 at 2:33:49 PM
Dimension String
Wed, Nov 22, 2006 at 3:05:15 PM
How to make an aligned dimension?
Wed, Dec 11, 2013 at 5:19:54 AM
When mirror why dimension won't stay the same
Fri, Mar 13, 2009 at 4:42:26 PM
CREATING DIMENSION STYLE w-embedded text?
Thu, Jul 24, 2008 at 1:33:50 PM
Page generation time: 0.6826
