Forums >> Revit Building >> Technical Support >> Publish to google earth issue
Tue, Jan 4, 2011 at 12:09:00 PM | Publish to google earth issue
quinn
I have downloaded google earth and the addin to publish from revit. I set up my 3d view while i also had google earth opened and tried to publish it.  It gives me a warning you must have google earth installed before you an publish.  I already have google earth installed???? So i checked where the program is located in my program files and its dumping the folder into the 32bit program file section rather than the 64 bit which tells me this is designed to run off that.  Im not sure if this has anything to do with the issue or not or what the problem is but i cannot publish anything to GE right now. Why does it request i install google earth when its installed and shows up in my list of installed programs?
Sat, Feb 9, 2013 at 11:00:01 PM | Publish to google earth issue
xXSuperDaveXx
Could only get this to work by installing Google earth v5, Which version are you running?
kml kmz file to google earth
Mon, Jan 30, 2012 at 5:02:43 AM
Rotating a model imported into Google Earth
Wed, Oct 24, 2007 at 8:54:53 AM
Revit to Google Earth
Mon, Feb 11, 2013 at 9:09:38 AM
Google Earth extension
Mon, Jun 9, 2008 at 5:39:13 AM
Revit into Google Earth COOL!!
Fri, May 16, 2008 at 9:00:29 AM
Page generation time: 0.2766
