Forums >> Community >> The Studio >> adding floors
Wed, Nov 2, 2005 at 1:58:51 PM | adding floors
larryhoops98
Hello, i am a student and want to learn how to put in floors. If you can help please write back. Thanks if you do.
Mon, May 14, 2012 at 12:23:47 PM | adding floors
From the HELP file .... Learn to use it because it will answer qustions like this.
Adding Floors
  1. Click Home tabBuild panelFloor drop-down Floor.
  2. Draw the floor boundaries, using one of the following methods:
    • Pick walls: By default, Pick Walls is active. (If it is not active, click Modify | Create Floor Boundary tabDraw panel (Pick Walls).) Select walls in the drawing area to use as floor boundaries.
    • Sketch boundaries: To sketch the profile of the floor, click Modify | Create Floor Boundary tabDraw panel, and select a sketching tool. See Sketching.
    The floor boundary must be a closed loop (profile). To create an opening in the floor, you can sketch another closed loop where you want the opening to appear.
  3. On the Options Bar, for Offset, specify an offset for the floor edges.
    NoteWhen you are using Pick Walls, select Extend into wall (to core) to measure the offset from the wall's core.
  4. Click Finish Edit Mode.
Adding 3rd floors to projects
Sun, Dec 16, 2007 at 7:38:19 PM
better floors
Fri, Jan 28, 2005 at 11:18:25 AM
My wishlist: Adding parameter in VIEW TITLE rfa
Tue, Mar 20, 2012 at 4:55:00 PM
Adding a floor around precast columns
Wed, Sep 21, 2005 at 5:50:29 PM
Adding a second floor into a six story building
Thu, Aug 21, 2014 at 12:02:52 PM
Page generation time: 1.1974
