Forums >> Revit Building >> Technical Support >> cut profile for walls sorted
Thu, Dec 30, 2010 at 4:20:58 PM | cut profile for walls sorted
Pele
Pele Avatar
Whilst still learning to use the cut profile tool I recieved this great result from the Autodesk Revit forums with regard to walls, follow the link
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Cut-Profile-command-is-clunky/td-p/2866496#M48811
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
big problem with edit cut profile????
Sun, Sep 11, 2005 at 9:38:48 AM
Cut profile on a linked file??
Thu, Oct 10, 2013 at 3:33:52 PM
Cut a profile with a reveal?
Wed, Jun 27, 2012 at 4:04:47 PM
Two walls created with walls by face in 2011, only one can edit profile?
Wed, May 16, 2012 at 3:04:14 PM
Cut Profile Line Weights (Revit Glitch?)
Tue, Aug 22, 2017 at 4:23:29 PM
Page generation time: 0.5536
