Forums >> Revit Systems >> Technical Support >> Red tee
Thu, Dec 30, 2010 at 12:09:29 PM | Red tee
maenhoudtbrecht
Hello,
 I have a problem width the following situation:In a project i have set up a class with the several client standards.Also i have made a reduction tee with the several standard (width look up table).
In the standards i have par example a redection tee 100x100x50 but i don't have 100x100x25.When i load the tee in the project he works perfect exapt when i have to make a tee 100x100x50 with at the third bend a pipe with a section 25. Revit set automatic a tee 100x100x25. But i didn't make them because in reality he don't exist.
In reality it is a tee par example 100x100x100 with a normal reduction on it.Is there a solution for this?
 thanks in advance
Brecht
pipe tee size
Thu, Jun 7, 2018 at 3:50:08 PM
Cable tray tee
Tue, Nov 1, 2016 at 7:29:06 AM
oval to round tee fitting family
Thu, Jan 13, 2011 at 4:25:41 PM
Elbow and tee's duct surface area
Mon, Feb 27, 2012 at 6:42:05 PM
Can't Get Rid of Demolition Red
Wed, Jan 15, 2025 at 7:43:06 PM
Page generation time: 2.1471
