Forums >> Revit Building >> Technical Support >> BACK 2 BACK TEXT IN RENDER
Thu, Dec 30, 2010 at 2:45:20 AM | BACK 2 BACK TEXT IN RENDER
online2000
online2000 Avatar
HI GIZMOZ/
IN REVIT 2011
any ideas on this one?
how can i avoid the back to back effect when creating a glazing OR "FENCE" type wall with RENDER materials that have cutouts with letters- i want to have the effect of a wall that is made of letters and without the repetative text on the other "skin" of the thickness of the material...
ie- is there a way to create a surface that has not thickness.. and thus give it a material?
thanks
and HAPPY NEW YEAR ALL!!!
E
eli
Mon, Jan 10, 2011 at 11:21:27 AM | BACK 2 BACK TEXT IN RENDER
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
Try using the Split Face and/or Paint tools and just apply the material to one side of the surface?
Brandon Pike | Owner/BIM Specialist
cad.web.print
website: http://www.thinkdesign-studios.com
blog: http://www.bimtionary.blogspot.com/
Mon, Jan 10, 2011 at 11:29:49 AM | BACK 2 BACK TEXT IN RENDER
online2000
online2000 Avatar
hey
was a good idea-- but not working out for me..
it doesnt give me a transparent layer aroudn the text..
eli
Mon, Jan 10, 2011 at 12:11:32 PM | BACK 2 BACK TEXT IN RENDER
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
Try this:
Set the default material of the wall to a transparent material?
And you could try this as a material:
Take a look at the Wood Stockade material in the library - use it as a base.
Create a jpeg of your repeated text - swap it out with the image map of the Wood Stockade material
Invert the colors of your repeated text jpeg so the text is white and the background is black - swap this out with the Cutout image map of the Wood Stockade material
Paint the one surface of the transparent wall using the new material - hopefully works? :-) I haven't tried it but it seems it should work.
cad.web.print
Tue, Jan 11, 2011 at 2:46:29 AM | BACK 2 BACK TEXT IN RENDER
online2000
online2000 Avatar
if i understood clearly- i should create a totally transparent material- and make that the base to the host wall---
and then create the split face and attach my a text material--
well- i did it and it worked!
WELL DONE!
great advice!
thanks BM
eli
Model for back to back water closets
Wed, Jul 22, 2009 at 4:32:41 PM
Title Sheet text sent to back? or transparent?
Wed, Mar 4, 2015 at 3:25:00 PM
Revit to Ram and back
Fri, Jun 3, 2011 at 4:07:47 PM
Is it possible to copy from job to job a piping layout like back to back toilets
Fri, Sep 25, 2009 at 3:54:07 AM
HELP..text relocating....project due
Wed, Sep 28, 2005 at 10:07:40 AM
Page generation time: 0.7636
