13 Users Online (11 Members):
Forums >> Revit Systems >> Technical Support >> All Revit Architecture Projects now open directly to Revit Structure
2 Posts No Rating |
Hi i recently installed the revit structure software on my pc jsut to do some calculations on one of my projects. The problem is that every single Revit project on my pc now opens directly with revit Structure. Is there a way to configure them to open directly with Revit Architecture?
yes, right click on a revit file, and the second item down should be "open with..." This will bring up a list of compatible programs, and you can choose the default. You should see both structural and architectural... if you don't see the revit architecture .exe, hit the browse button, and go find where it's hiding. hope that helps
Edited on: Wed, Dec 29, 2010 at 5:50:29 PM
2 Posts No Rating |
The weird thing is that in that menu only appears Revit.exe. And when i look for the revit architecture executable it still appears only as revit.exe and opens in revit structure.
Revit Architecture can't open a large file |
Thu, Feb 6, 2014 at 12:21:01 PM
REVIT STRUCTURE VS ARCHITECTURE |
Tue, Apr 21, 2015 at 9:32:48 AM
Metalic Structure in Revit Architecture |
Fri, Dec 3, 2010 at 1:10:10 PM
Revit Architecture / Revit Structure Coordination Issues |
Fri, May 7, 2010 at 10:19:04 AM
How to change "opens with" settings? |
Fri, Jun 1, 2012 at 2:04:22 PM
