Forums >> Revit Building >> Technical Support >> Rock Wall Modelling
Wed, Dec 29, 2010 at 11:59:52 AM | Rock Wall Modelling
Altruant
Hi,
I am trying to model a rock wall in Revit 2011. Is there an easy way to achieve the following with curtain walling? Is it possible to model a 20m x 4m wall without slowing revit to a tortoise?
I'm just currently trying to get a few idea how to achieve it quickly without too much pain.
Many thanks
Wed, Dec 29, 2010 at 12:52:22 PM | Rock Wall Modelling
I would not use a curtain wall for this.
Most of the time, materials are best represented by image files and bump files to create the texture.  What you are showing has too great of a texture to do this unless your views are at a distance.
And I think that is really the question.  If most views are not closeup, then I would still use the normal process.  If you do have some special rendered views that require more intense modeling, then I would first consider just adding the textures in photoshop or something like that.
You could look at a face-based family that could be applied where you need this look but I would not do it for the entire model.
Thu, Dec 30, 2010 at 10:31:17 AM | Rock Wall Modelling
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
modeling rock or even natural occuring boulders outside is difficult. www.cgtextures.com might help if you are looking for textures they have some good ones.
Sun, Jan 2, 2011 at 8:21:55 PM | Rock Wall Modelling
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Whilst I wouldn't recommend modelling this and would use a texture.  It is possible to model using the massing tools and a curtain panel pattern based family.
Checkout Zachory Kron's blog for some cool examples. http://buildz.blogspot.com/
Regards,
Chris.
modelling
Mon, Apr 10, 2006 at 8:22:58 PM
rock veneer wall
Sat, Feb 23, 2008 at 9:53:02 PM
Need really a good looking rock material!
Mon, Sep 1, 2008 at 2:04:24 AM
Sheet rock won't wrap at stacked wall conditions
Mon, Jan 20, 2014 at 1:10:02 PM
Rock Fill Region
Mon, Nov 12, 2012 at 10:04:47 AM
Page generation time: 0.5612
