Forums >> Revit Building >> Technical Support >> Help,what's wrong with my door family
Tue, Dec 28, 2010 at 5:13:31 AM | Help,what's wrong with my door family
fairywiner
look, I have made a door family,and it looks quite good in the family, as picture 1, and then I inserted it in to my project the sweep have go in to my wall.
and when I finished door swings in my family, it still looks so bad in my family when I inserted into my family.
Edited on: Tue, Dec 28, 2010 at 5:19:02 AM
沧海月明珠有泪
Tue, Dec 28, 2010 at 5:15:08 AM | Help,what's wrong with my door family
fairywiner
this is my family
沧海月明珠有泪
Tue, Dec 28, 2010 at 5:17:54 AM | Help,what's wrong with my door family
fairywiner
this is my projects file
沧海月明珠有泪
Tue, Dec 28, 2010 at 12:59:18 PM | Help,what's wrong with my door family
4 Stars: 205 Votes
That door is wrong, create a parameter to control that "width" BUT when you are creating those model lines you must lock them (whole padlocks), delete them and do it again, about the sweep, create that in a 3D view and use the "Pick Path" tool and select both lines and the arc then drag those lines to the bottom of that door.
Tue, Dec 28, 2010 at 8:56:31 PM | but I don't know how to add that door parameters.
fairywiner
but I don't know how to add that door parameters. see as pictures I changed from your picture.
and why the mullion position change so much when the door family inserted into the family. see as picture5.
沧海月明珠有泪
Wed, Dec 29, 2010 at 1:04:59 PM | Help,what's wrong with my door family
4 Stars: 205 Votes
I'm somewhat sure that you do not know much about creating families, am I right? well, my advise is that you should first study the tutorials, here you have the link from Autodesk were you can download "Families_guide_tutorials", like you can see you have in "Chinese" too, http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13376394
You can search in Youtube for free videos about creating families.
Watch this videos:
http://screencast.com/t/W5lbIvm4ll
http://screencast.com/t/Ihyq1juXX3j0
Wed, Dec 29, 2010 at 8:16:34 PM | I just want to say thank you very very much for your help!
fairywiner
Yes,I have just studied two revit  tutorials and I am not very familiar with revit,espacially some specific skills that did not mentioned too much in the tutorials files. But I do think revit can enhance large work efficiency.  The files you send me did great help for my learning to make family, so thank you very very much for your help.
沧海月明珠有泪
Thu, Dec 30, 2010 at 8:06:56 AM | Help,what's wrong with my door family
I suggest that you also visit this site :  http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11091739 and for sure dowload and thoroughly read the Families Guide
Family Editor: works... then doesn't!
Fri, Sep 2, 2005 at 5:23:05 PM
Door swing, something going wrong
Fri, Feb 19, 2010 at 3:54:27 AM
Automatic dimensions to door family defaulting to wrong side of door.
Fri, Jul 22, 2016 at 9:58:33 AM
Door family parameter problem
Tue, May 17, 2005 at 7:18:43 AM
Door color varies in different views [ 1 2 ]
Wed, Nov 14, 2012 at 2:39:14 PM
17
Page generation time: 3.6773
