Forums >> Revit Building >> Technical Support >> Schedule Sorting Multiple Letters or Numbers
Mon, Dec 27, 2010 at 12:11:17 PM | Schedule Sorting Multiple Letters or Numbers
archqi
I am trying to sort a schedule of items with type marks that start with A through Z and then follow on with AA through ZZ. The issus is that in the schedule it goes in the order A, AA, B, BB, C, CC, etc. I would like the schedule to list the order A through Z and follow with AA- through ZZ. Is there a way to correct this without creating some kind of perameter that would not show in the schedule? I am using Revit Building 2011.
Mon, Dec 27, 2010 at 6:20:35 PM | Schedule Sorting Multiple Letters or Numbers
Sorry but REvit uses straight ascii sorting and AA is before B.  Perhaps you should use a different sequence or add another parameter to sort by.
Thu, Nov 12, 2020 at 5:37:00 PM | Schedule Sorting Multiple Letters or Numbers
casquatch
Most likely too little....wayyyyyyyy too late. But you can put in a Unicode Control character in front of the AA, AB, etc. values and it will sort those after the A-Z.
You can't directly insert the unicode control character within the schedule or the type mark field, but you can copy one from another area and then paste it in front. I just edited a sheet name, inserted one there, then selected all after that and hit Ctrl+C, then went to the beginning of my Type Mark and hit paste. It's invisibly, but when you put it only in front of the AA, AB, etc. it works just fine to push them all to the bottom of that list.
Anyway, hopefully someone else will find this solution helpful if they are venturing down this road at some point (like I was).
Schedule sorting with letters
Thu, Jun 16, 2011 at 7:00:17 AM
Revision numbers and letters
Sat, Apr 11, 2020 at 5:35:03 AM
Total Mark Numbers vs Total Pieces in a Schedule
Wed, Jan 14, 2015 at 1:23:39 PM
Window sashes with different window numbers in the window schedule
Tue, Mar 19, 2024 at 11:49:53 AM
Reordering Sheets
Thu, Nov 1, 2018 at 2:09:29 PM
Page generation time: 1.8207
