Forums >> Revit Building >> Technical Support >> Plumb Cut to ceilings
Wed, Nov 2, 2005 at 1:44:25 AM | Plumb Cut to ceilings
cadjockey
Hi all, When creating a sloped ceiling revit automatically plumb cuts the ends. How do I stop this from happening? cadjockey
Wed, Nov 2, 2005 at 2:22:25 AM | RE: Plumb Cut to ceilings
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Unfortunately ceilings don't have the same options as roofs for the edges. So two options. Do it as a roof... OR create an in-place void family to cut the ceiling edge as required.
Wed, Nov 2, 2005 at 3:36:12 AM | RE: Plumb Cut to ceilings
cadjockey
Hi Mr Spot, That's a real shame. To have such a great tool and have it let you down at the post. Anyway, If I create it as a roof will it show up on the ceiling plans and can I tag it on the ceiling plan appropriately? Also, In using void sweeps to trim the edges of elements ie. roof/fascia junction, I am finding it very difficult to locate the void sweep once again in order to use it somewhere else. Sometimes the rollover finds it. Most times it doesn't. Is there another way? cadjockey Post edited on 2005-11-02 03:36:49
How to not plumb cut a graded slab
Mon, Jun 20, 2011 at 2:02:18 PM
web joist and plumb cut
Tue, Nov 29, 2005 at 4:48:03 PM
Pitch roof problems- double-plumb roofs with different height edges
Thu, Feb 21, 2008 at 2:54:46 PM
Rafter cut different on each side of roof
Tue, Jun 1, 2010 at 12:29:00 PM
Custom Rafter Cut for plumb plywood and square standing seam
Sun, Dec 15, 2013 at 10:26:27 AM
Page generation time: 1.5145
