27 Users Online (25 Members):
Forums >> General Discussion >> Wishlist >> Section reference in text.
83 Posts No Rating |
Is there any way to put a parametric section reference in a text note? For example, “SEE DETAIL 3/A3.1 FOR TYPICAL CONNECTION” I have been using section bubbles referenced to another view and then turning off the tail and shortening the section line until it doesn’t show. This works but it is rather clunky.
61 Posts No Rating |
Have you tried creating a new seciton head? I'm guessing if you simply build one with an instance-based text parameter for your notes placed alongside the referencing detail/number, that'd do what you want it. Okay so you'd have to have different section types in the project, and they might not look how you want in certain orientations - but it's an idea... Personally, I'd question why someone is looking at a drawing if they don't know a section line / callout region is going to explain something further if they navigate to the drawing without being told as much. I mean, really, it's like the whole "to be read in conjunction with relevant drawings" type of disclaimer - it's obvious to the point of nonsense.
Check out my posts here... http://www.revitcity.com/forums.php?action=viewthread&thread_id=11887
22 Posts No Rating |
There is a new tool called "View Reference" in 2013. See here:
http://revitoped.blogspot.com/2012/03/revit-2013-view-references.html
WOW - Thanks for posting this - I will have to try this out. Now if we could just use that in a schedule ...< patience.
Note - to use this, you must have a view reference tag loaded. This does work in legend notes.
Reference Labels on Section Heads - MISSING |
Tue, Dec 6, 2005 at 5:02:48 PM
Detail reference in text. |
Tue, Feb 7, 2017 at 11:26:32 AM
Text Referencing a View |
Tue, Dec 16, 2008 at 10:15:01 PM
How do I make a section that will not reference a detail or make a view? |
Tue, Nov 11, 2008 at 6:18:55 AM
Aligning text a section head |
Fri, Mar 2, 2007 at 1:17:11 PM
