16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Site Topo with colour
148 Posts No Rating |
Greetings ... Here is a curious one. My designer wishes to present a site plan with the topography coloured - different colours for different elevaitons. Please see the attached PDF. - Is there a facility in Revit that will assist with identifying the different topography elevations by colour?
- Also could this be done for a section?
I suspect that Filled Regions will be the only way to go, but I don't look forward to tracing the contour lines to create the filled regions (don't know if I can trace contour lines). Any strategies will be appreciated, thanks.
Ian Shafer
Principal Consultant
True North S&F Consultants |
Export to CAD to get the linework, then either fill it in CAD and import (probably easier) or import the linework into seperate filled area sketches. NOTE: This is all only 2D.
Can I imort CAD linework into a sketch mode? I tried that once but had no success.
Ian Shafer
Wall on Topo Site |
Wed, May 28, 2008 at 5:00:38 AM
RAC 2009 - Topo Site Work |
Fri, May 9, 2008 at 3:08:34 PM
level elevation doesn't match elev point in topo / site plan |
Wed, Dec 18, 2013 at 4:05:00 AM
13
topo. surfeaces |
Thu, Jan 10, 2008 at 9:59:44 AM
Could Revit allow curb or sidewalk sweeps to be attached to site topo edges? |
Wed, Apr 26, 2006 at 4:42:17 PM
