15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Groin Vault Ceiling
4 Posts No Rating |
I'm modeling a house in Revit based on 2d plans. The ceiling plans call for a "Quine Vault Ceiling" which I'm assuming would be like a Groin vault? Any idea how to model this? Thanks.
Do you have any image about that "Quine Vault Ceiling"?
If you google this you will only find reference to this term in some French books. Good luck with this.
4 Posts No Rating |
Here are the images that I have to go by to model this vault. I'm mostly interested in what Revit tool I should use to make a vaulted ceiling. Thanks.
Something like this? Simple, create a "Mass" and use two voids to cut that mass then apply roof by face, it's not in "Ceiling" category but solve your problem.
4 Posts No Rating |
Thanks a lot, I got it to work that way. My only problem now is that my roof only appears in 3D, not in 2D section, or plan - even though "roof" is checked on in my View Properties, so I can't figure it out.
if you modeled as mass object you must turn on mass in the VG
I said: "Simple, create a "Mass" and use two voids to cut that mass then apply roof by face,..."
Trouble with creating a Ribbed Groin Vault |
Sun, Nov 25, 2012 at 12:04:44 PM
How do I create a Barrel Vault Ceiling |
Fri, Apr 26, 2013 at 4:09:23 PM
Tue, Oct 21, 2008 at 10:12:04 AM
Barrel Vault ceiling problems |
Mon, Nov 22, 2010 at 4:58:04 PM
Barrel vault dormer opening |
Thu, Jun 21, 2007 at 2:22:49 PM
