Forums >> General Discussion >> Revit ROI >> Floor Plan View Disapperance
Wed, Dec 22, 2010 at 7:22:04 AM | Floor Plan View Disapperance
JB2010
I cannot see my floor plan views but I can see the section,elevation and 3D views.  Has anyone had this problem?  What can I do to get back my plan views?
Wed, Dec 22, 2010 at 7:33:45 AM | Floor Plan View Disapperance
Please be clearer when you ask your questions?
Do you mean you don't have any plan views in the browser?
Did you delete the views?
Fri, Dec 24, 2010 at 4:45:09 AM | Floor Plan View Disapearance
JB2010
I have a project that list my views in the project browser but when I select the floor plan that I want to see the screen is blank.  When I select the elevation veiws, the view can be seen.  What could cause this?
Fri, Dec 24, 2010 at 5:22:12 AM | Floor Plan View Disapearance
JB2010
Yes, the views are listed in the browser....
Fri, Dec 24, 2010 at 8:41:48 AM | Floor Plan View Disapperance
  1. The plan may be out of view - Type ZA for zoom all.
  2. You don't say what version you are on.  Do you have all your updates installed?
Thu, Dec 30, 2010 at 10:47:56 AM | Floor Plan View Disapperance
mhbn4
2.5 Stars: 4 Votes
you must also check view range in plan view and adjust its view depth and cut plan and so on
Thu, Dec 30, 2010 at 5:55:24 PM | Floor Plan View Disapperance
JB2010
"Thank you Thank you!!!" ZA worked....
Wed, Jan 5, 2011 at 6:26:37 AM | Floor Plan View Disapperance
markitekdesign
markitekdesign Avatar
4.5 Stars: 74 Votes
WW is genius,without knowing the software,he can answer the question..hehe
https://www.facebook.com/groups/257952100885689/
''GOOD WORK IS NEVER CHEAP,AND CHEAP WORK IS NEVER GOOD"
Fri, Nov 15, 2013 at 7:02:35 AM | Floor Plan View Disapperance
slafley
I am having the same issue as JB 2010: I have floor plan views in my properties palette, but when I click on them, all I get is a blank screen. I have tried Zoom All and the view range appears to be in order. I have also tried re-making the views. The new floor plan view comes in blank. Elevations and 3d view are still there, as are some plan views that were already placed on sheets. Any other suggestions?
Fri, Nov 15, 2013 at 7:20:41 AM | Floor Plan View Disapperance
slafley
Oops, ZA was working, I just still couldn't see anything once it was zoomed.
Fri, Nov 15, 2013 at 7:39:45 AM | Floor Plan View Disapperance
#11
If you used ZA and the screen looks white, be aware that you have model objects at extreme distances from each other.  Use a crossing window in the corners of your ZA window to find what these are.  You probably have things you will want to remove.
PLAN REGION VIEW DEPTH CHANGE OVERALL FLOOR PLAN
Fri, Aug 29, 2014 at 1:27:29 PM
RCP IN FLOOR PLAN VIEW
Sun, Nov 2, 2008 at 1:32:31 PM
Floor Plan associated to wrong level...
Fri, Jul 2, 2021 at 3:23:05 PM
Multiple sheets from same floor plan view with different scales?
Fri, Aug 1, 2008 at 12:01:43 PM
copy & paste detail group from one plan view to another plan view (2017)
Tue, Nov 29, 2016 at 4:57:42 PM
Page generation time: 0.8182
