Forums >> General Discussion >> Revit Project Management >> no print
Wed, Dec 22, 2010 at 1:46:11 AM | no print
mhbn4
2.5 Stars: 4 Votes
how it is possible to have some lines and use them as guide or helper lines but not having them in the print
Wed, Dec 22, 2010 at 3:27:06 AM | no print
jonezy
if im getting the question, can you not use reference planes/lines as these dont print
Wed, Dec 22, 2010 at 7:12:24 AM | no print
mhbn4
2.5 Stars: 4 Votes
thanks alot
Wed, Dec 22, 2010 at 8:26:55 PM | no print
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Use grids!  Or detail lines, or whatever it takes -- it doesn't really matter because you should have a separate view for printing from, cleaned up, with unneccessary objects turned off. Don't use model lines though.
When I use detail lines because snaps are uncooperative, I delete them afterward.
As for snaps -- the automatic dimensions try to pick the most sensible thing to dimension from, but if they guess wrong you can grab the blue dot and pull it to what you want, and then enter a new value in the box to move your object.  Fastest way to rationalize everything.
Electrical shows up in plan view, but will not print.. Help!
Mon, Jul 21, 2014 at 3:04:35 PM
how I print 2 or more sheets in the same print sheet?
Mon, Aug 31, 2009 at 9:36:48 AM
Sheets missing when I go to print
Wed, May 20, 2015 at 9:36:38 PM
12
Portions of the model are missing only on print
Sun, Sep 21, 2014 at 11:58:29 PM
putting a print on glass
Fri, Apr 23, 2010 at 6:13:19 AM
Page generation time: 0.0815
