Forums >> Revit Building >> Technical Support >> How Do You Bring Back A Missing Title Block?
Tue, Dec 21, 2010 at 10:34:32 AM | How Do You Bring Back A Missing Title Block?
Busch1724
This may be a silly question and looked around the forum a bit for an answer along with some google searches.
I am using Revit 2011. The sheet that contains the title block is sheet A1-First Floor Plan. The default D Size Title Block for the sheet is missing/deleted by accident. How do I bring it back in if it is missing?
I know I can copy the first floor plan and create a new sheet and add the copied view into the new sheet, but I don't what to have to do that for numbering purposes and so on.
Tue, Dec 21, 2010 at 10:41:54 AM | How Do You Bring Back A Missing Title Block?
I assume you mean the views are still there.  Just find your title block in the annotation families.  Expand the category (+) - grab the titleblock and drag it onto your sheet.  Adjust ist location and all will be fine.
Tue, Dec 21, 2010 at 11:41:26 AM | How Do You Bring Back A Missing Title Block?
Busch1724
Thanks, I knew it was easy. I just didn't think of it.
Missing Delta Symbol in Title Block Revisions/Issues Log
Fri, Sep 5, 2014 at 7:12:30 AM
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
'Draft' stamp in title block won't show
Fri, Jun 12, 2015 at 6:55:20 AM
How to import my title block from AutoCAD?
Mon, Sep 10, 2007 at 4:25:43 PM
12
In the default Revit Templates i couldnt find revit title block
Fri, May 23, 2014 at 7:22:23 AM
Page generation time: 4.4058
