Forums >> Revit Building >> Technical Support >> import to revit from autocad
Tue, Dec 21, 2010 at 3:59:21 AM | import to revit from autocad
akilic41
Hello,
 I want to import dwg file (autocad 2011) which contains only property lines to revit 2009. But I always get " some elements were lost during import. ActiveX or some proprietry components cannot be imported. Try exploding the file in Autocad, or setting proxy graphics to 1."
I think the problem is the version because there was no problem before using autocad 2011 instead of autocad 2008.
Can anyone help me to achieve this?
Thank you so much in advance.
Tue, Dec 21, 2010 at 4:46:37 AM | import to revit from autocad
4 Stars: 205 Votes
Before you import that file into Revit you must clean the file, delete all hatch, text, explode polylines and blocks then purge the file.
Tue, Dec 21, 2010 at 4:48:20 AM | import to revit from autocad
akilic41
Please don't consider this issue. I solved the problem.
I saved the autocad file as autocad 2007 in files of types option then Import was successful.
Thu, Jan 31, 2013 at 9:34:25 AM | import to revit from autocad
paccino
Thanks
This also worked for me
Sun, Mar 31, 2013 at 11:37:12 AM | akilic41
acdclau
Quoting akilic41 from 2010-12-21 04:48:20
Yes, this also worked from me! THANKS!!!!!!!!
Autocad Import Problems
Tue, May 5, 2009 at 1:55:33 PM
Revit Crash when Autocad Site plan Import
Wed, Jan 7, 2009 at 4:51:26 PM
Import topo surface from AutoCAD to Revit??
Thu, Oct 17, 2013 at 12:49:05 PM
Autocad import problems
Thu, Jan 20, 2011 at 1:54:38 AM
import revit renderings into autocad
Mon, Jan 17, 2011 at 2:18:17 PM
Page generation time: 2.1932
