Forums >> Revit Building >> Technical Support >> Halftone & View Ranges
Mon, Dec 20, 2010 at 11:58:34 PM | Halftone & View Ranges
ezarun
Hi Everyone, is there a way to Change the Visibility of Lower level Plans to be Changed to Halftone?. I dont want to Underlay the Plans & niether do I want to change the Visibility to Halftones from VG Dialog Box, It must be done from the View range Dialog Box. Cant seem to get thisSad
Arun
BIM Manager,
STH
Tue, Dec 21, 2010 at 7:20:10 AM | Halftone & View Ranges
You can not do what you want the way you want to do it.
Tue, Dec 21, 2010 at 7:39:48 AM | Halftone & View Ranges
ezarun
Can you Pl Suggest the Best way to do this, tried VG Halftoned the Stairs, but the Problem with this was the Stair on the same level, was also halftoned (e.g Viewing 7th Floor Plan Stair along with a few steps in the Landscape below on the Ground Level)
Arun
BIM Manager,
STH
Tue, Dec 21, 2010 at 8:01:10 AM | Halftone & View Ranges
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
When you set the View Depth in the view range to below the Bottom it will use the <Beyond> linestyle to show any items "below" the Bottom. You can try changing the <Beyond> linestyle to gray and see if that gets you closer to what you want.
Thu, Dec 23, 2010 at 1:34:50 AM | Halftone & View Ranges
ezarun
The Problem with this is in a typical Model there are lots of categories, like models, stairs etc...and Lines, it would mean that each and evry category has to be halftoned...which is not practical....
Arun
BIM Manager,
STH
Mon, Dec 27, 2010 at 8:46:15 AM | Halftone & View Ranges
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I am actually talking about the <Beyond> linestyle. Go to Manage Tab-->Additional Settings-->Linestyles and find the <Beyond> linestyle. Change its color to gray and it will grayscale all items that show up beyond the "Bottom" of the view range. The "View depth" setting uses the <Beyond> linestyle to depict the visible geometry beyond the bottom of the view range.
Thu, Jan 20, 2011 at 7:05:08 PM | Halftone & View Ranges
ezarun
Makes Sense, and seems to work, Thanks James.
Arun
BIM Manager,
STH
Design Options Halftone?
Tue, Nov 20, 2018 at 10:58:56 PM
Revit MEP 2012 - Halftone not Working...
Fri, Oct 5, 2012 at 12:47:21 PM
halftone hatch/fill pattern?
Wed, Jan 16, 2008 at 10:14:12 AM
RVT Link Halftone
Thu, Oct 11, 2012 at 7:56:04 AM
how does view ranges work in ceiling views?
Sat, May 11, 2019 at 2:42:35 PM
14
Page generation time: 8.2995
