Forums >> Revit Building >> Technical Support >> SECTIONS AND LEVELS
Mon, Dec 20, 2010 at 10:58:51 AM | SECTIONS AND LEVELS
Bimman
Bimman Avatar
1 Stars: 2 Votes
I JUST LAID IN A SECTION MARKER AND FOR SOME REASON MY LEVELS ARE NOT SHOWING UP.  THIS IS THE FIRST TIME THIS HAS EVER HAPPENED.  EVERYTHING IS TURNED ON ION THE VIEW, SO I SHOULD BE SEEING THEM. BUT THEY ARE MISSING.  ANY IDEAS? SPENT THE LAST HOUR TRYINH TO FIND THEM.
PWD
Mon, Dec 20, 2010 at 11:14:22 AM | SECTIONS AND LEVELS
Are you sure the extends of the level cross the section?  Levels are only visible if they are cut by the view.
Mon, Dec 20, 2010 at 11:42:17 AM | SECTIONS AND LEVELS
Bimman
Bimman Avatar
1 Stars: 2 Votes
THAT IS WHAT IT WAS, BEEN USING REVIT SINCE 04 AND THAT IS THE FIRST TIME THAT HAS EVER HAPPENED TO ME.
 THANKS
PWD
Mon, Dec 20, 2010 at 2:15:42 PM | SECTIONS AND LEVELS
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Wow, that's surprising.
Levels and Grids have to be cut by the view to display in the view.
Plan views have a cut plane and view range that have an impact.
Sections and Elevations have clipping planes.
Then there are scope boxes.
Mon, Dec 20, 2010 at 3:05:06 PM | SECTIONS AND LEVELS
Bimman
Bimman Avatar
1 Stars: 2 Votes
guess i must have always been lucky and put sections in the correct spot.
PWD
Levels, Disappeared. [ 1 2 ]
Sun, Sep 24, 2017 at 7:44:33 AM
16
Floor and Ceiling Levels
Sat, Jul 15, 2006 at 9:38:55 PM
VISIBILITY OF LEVELS
Tue, Jul 13, 2010 at 12:45:49 PM
levels in sections/elevations
Tue, May 9, 2006 at 11:18:21 AM
What is your standard for anotating levels
Mon, Nov 10, 2008 at 12:40:39 PM
Page generation time: 1.8053
