Forums >> Revit Building >> Technical Support >> Floor Elevation
Sat, Dec 18, 2010 at 6:48:14 PM | Floor Elevation
akilic41
Hello,
I have four buildings and each one must start with different elevation (base floor). First I have drawn one block and then created other blocks by copy-paste method (I don't know different method). At this moment stopped because I have to give different elevation value for each block.  First block-basement start with 0, the other blocks              starts with 1.5 m
Please help me if anyone knows the solution.
 Thanks in advance.
Ahmet KILIÇ
akilic41@yahoo.com.tr
Sun, Dec 19, 2010 at 7:33:19 AM | Floor Elevation
4 Stars: 205 Votes
Look in your HELP menu how you can work with "Linking Models"
Sun, Dec 19, 2010 at 8:47:17 AM | Floor Elevation
Typhoon is right, If you have 4 seperate buildings, then you should consider 4 different models and link them together.
Or is this just a massing study?  You metion creating blocks.  Is that a mass or are you using an autocad term here?  If it is a mass, then you should consider seperate masses.  In place family extrusions are meant for single placement, not multiple.
Sun, Dec 19, 2010 at 9:17:30 AM | Typhoon
akilic41
Quoting Typhoon from 2010-12-19 07:33:19
Thank you very much.
I applied linked models to my project. It solved my problem.
Elevation Markers: visible on all floors
Mon, Nov 7, 2011 at 12:24:27 PM
Floor tag - elevation spot
Thu, Apr 27, 2017 at 7:20:09 AM
Elevation Level Marker Associated To Wrong Floor Plan
Wed, Feb 25, 2015 at 10:44:23 AM
Hide the elevation circles from floor plan
Thu, Nov 15, 2007 at 11:07:46 AM
Elevation Lines and floor plans
Wed, Jan 26, 2011 at 12:21:39 PM
Page generation time: 3.8896
