17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Elevation tags!!!
20 Posts No Rating |
Hi, I have been using Revit 2009 for a while and now I am getting introduce into 2011. I can not fid the way to change the size of the ELEVATION TAG like I used to, any help???? Alberto
28 Posts No Rating |
They've completely changed the way elevation tags are done in 2011. You now create 2 seperate annotations; the elevation symbol itself (usually the circle or square that showed the sheet number in previous releases) and the pointer (the arrow showing the direction of the elevation view). While not quite as easy to work with, this new style allows for the flexibilty to create a large number of custom elevation tag styles. Hope that helps....good luck.
----------------------------------- The Leffler Group |
Kbeegles... Thank you for your answer, after I search online you are completely right Alberto
Hiding View Name in Elevation View Tags |
Fri, Jan 21, 2011 at 6:47:39 PM
Elevation Tags |
Tue, Oct 23, 2007 at 4:30:06 PM
Custom Elevation Tags |
Thu, Mar 17, 2011 at 5:09:02 AM
2011 interior elevation tags |
Thu, Dec 23, 2010 at 11:44:57 AM
Multiple Elevation Tags |
Mon, May 24, 2010 at 3:20:16 PM
