14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Set color of a pipe in 3D without the pipe tool
16 Posts No Rating |
Hello all, Is there a solution to set the 3D piping in a color without the pipe tool.Par example, I have warm and hot water. So I want to see the warm water in red and the cold water in blue.As you know is this with the paint tool a lot of work. Is there a way to do this in a easier way. In 2D we also have found the solution but in 3D it is a mistery. Thanks in advanced
20 Posts No Rating |
Play around with filters, hit "vv" or "vg" to pull up the visibility graphics menu, then go to the filters tab. Under filters there should be default filters set up for hot/cold domestic water and you can change the line color etc. under that. If there is not a default filter set up and you are having trouble getting one to work, let me know and I will tell you what I do. Goodluck.
owkay, thanks
PIPE COLOR |
Thu, Apr 1, 2010 at 10:43:51 AM
pipe dimensions |
Wed, Dec 2, 2015 at 7:47:03 AM
Pipe Accessories and Pipe Type parameter |
Tue, Dec 27, 2011 at 11:25:39 AM
Trim HSS Round pipe into another HSS Round pipe |
Tue, Apr 3, 2012 at 4:39:45 AM
Revit MEP 2012 - Transfer Pipe Size & Pipe Materials bug? |
Fri, May 18, 2012 at 10:04:27 AM
