22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> How the heck can I get line styles to Families?
16 Posts No Rating |
You would think that it is simple to draw a dashed within the family editor. But the line type options for symbolic lines or model lines are not available inside the family editor. Does anybody know how I can add a line type to a family?
You can add a new line type in Object styles and set the line type. You can create a new line type under additional settings.
I can create the line there but it dose not show up in the family editor. What am I doing wrong?
I figured it out. I need to be inside the family editor and activate the object style dialog there. Easy peasy lemon squeezy once you know. Thanks for pointing me in the right direction
hey can you tell me how you did it .. because i am facing same issue
Go into your Visability Graphics by typing VV then click on object styles, under the Model Objects tab create new.
inside the family or the project ???
If you are trying to create it for a family you do it in the family.
>Go to the manage tab.
>Click Object styles under settings.
>You can edit existing line types or make new ones.
>The go click on the lines you'd like to change and change the sub category.(Sub category will be come available under the modify tab.
These line types will carry over with your family when you load it in to your project.
line styles in families |
Tue, Mar 10, 2015 at 6:54:38 PM
Removing Line Styles |
Mon, May 8, 2017 at 2:21:04 PM
Associating Line styles with patterns |
Tue, Sep 18, 2012 at 11:30:05 AM
Deleting Line Styles |
Tue, Aug 5, 2014 at 2:57:29 PM
Object Styles |
Mon, Apr 5, 2021 at 9:39:38 AM
