22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> sheet graphic override
hi, am using rac 2011 and am having a problem whem i try to change the visibility/graphic override in a sheet, when i do that it changes in the original view in the model . how can i change it in the sheet without effecting the original view ???
Your question is not clear. Do you mean view instead of sheet? You can over-ride graphics in a view using the VG settings.
the problem is when i overrride th e greaphics in the sheet it only effect the sheet itself but not whats inside of it and if change what is inside of it, it effects the original view
RIGHT! A sheet is just the "paper" .... and the border and if you add anything in "paper space". To change a view, you have to activatte the view and change the VG settings for the view. BUT - VG settings are only for that view - none others. And since a view can only be placed on one sheet, what is your problem?
my problem is that i dont want the original view to be effected by the changes i made in the sheet and it does get effected.
LOOK - You don't seem to understand. A view is just a view. Changes made in VG in a view do not affect the model. You can have more than one view that shows the same thing. BUT YOU CAN ONLY PLACE A VIEW ON ONE SHEET ! Duplicate your view (with detailing if you want) - place one on this sheet and change the VG of that view. IT WILL NOT AFFECT THE DUPLICATE VIEW!
Dual Phase Graphic Override? |
Tue, Apr 28, 2009 at 9:23:26 AM
is it possible to disable phasing Graphic Override on a view |
Thu, Jun 8, 2017 at 3:34:46 PM
Graphic Override and Curtain Walls |
Tue, Mar 3, 2009 at 7:26:02 AM
11
Override Phase Filter for Specific View only |
Fri, Nov 4, 2016 at 9:45:40 AM
CURTAIN GRID BASED ELEMENTS CANNOT BE GROUPED |
Tue, Oct 28, 2014 at 12:55:23 PM
