Forums >> Community >> The Studio >> how to unlock ??
Tue, Nov 1, 2005 at 4:49:10 AM | how to unlock ??
why8888
may be it is easy to unlock? but, when i placed a wall next to curtain wall then just a little bit not line up, so i need to pick up the wall to move a little bit, the problem is i only pick up the wall, not the whole stuff? why8888
Tue, Nov 1, 2005 at 9:58:47 AM | RE: how to unlock ??
Rythmick
5 Stars: 2 Votes
The best method which is fast and easy is to use the "Align Tool" if you can. Another method is before you move your wall, you can use the "Pin" tool to pin down the joined items you do not want to move. Another method is to select the wall you want to move and "right click" the blue dots on the wall ends and select "Disallow Join". Once you move the wall you can reset the dots to "Allow Join". Post edited on 2005-11-01 15:55:49
Wed, Nov 2, 2005 at 4:58:00 AM | RE: how to unlock ??
why8888
thanks why8888
unlock finish materials on both sides of wall
Wed, Mar 30, 2011 at 4:14:42 AM
stacked wall- can I unlock components?
Wed, Jan 28, 2009 at 12:54:13 PM
window not cutting joined roof
Mon, Mar 6, 2017 at 3:59:28 PM
moving walls
Thu, Aug 1, 2013 at 8:26:58 PM
Confusing CONSTRAINS
Wed, Sep 7, 2011 at 1:15:31 AM
Page generation time: 1.6937
