Forums >> Revit Building >> Technical Support >> Linetype of Dimension line
Wed, Dec 15, 2010 at 11:56:55 PM | Linetype of Dimension line
Bansri
 Hello....
Can we change the linetype of the dimension line?
I want the dimension line to be dashed.. is it possible to do that in Revit?
thanks...
Thu, Dec 16, 2010 at 4:56:36 AM | Linetype of Dimension line
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Not that I'm aware of, only lineweight and colour controls...  Sometimes you standards will need to flex a little...
Regards,
Chris.
Mon, Mar 28, 2011 at 12:56:46 PM | Linetype of Dimension line
iamian33
iamian33 Avatar
Further to this ...
Is it possible to manage the line weight or colour of (just the) dimension extension lines?  I'd like to have the extension lines either half-toned or Grey to reduce confusion between dimensions and the elements being modeled.
Ian Shafer
Principal Consultant
True North S&F Consultants
Mon, Mar 28, 2011 at 1:48:13 PM | Linetype of Dimension line
Same answer as Mr. Spot's previous answer.
Mon, Mar 28, 2011 at 3:02:12 PM | Linetype of Dimension line
iamian33
iamian33 Avatar
thanks WW.  I was suspecting that ...
Ian Shafer
Fri, Aug 2, 2013 at 11:40:19 AM | Mr Spot
Avex
Quoting Mr Spot from 2010-12-16 04:56:36
"Sometimes you standards will need to flex a little..."
Change my standars? Are you serious? Revit MUST to change theirs, Revit MUST be the flexible one.
Still can't change the linetype in 2013 nor 2014?
Edited on: Fri, Aug 2, 2013 at 3:14:50 PM
Fri, Aug 2, 2013 at 11:54:32 AM | Linetype of Dimension line
You talk amout lame - You just joined today.  No other posts - no experience and you just came in here to post this?
archigrafix
5 Stars: 4 Votes
Avex, I agree with you. It's not an easy job to get custom graphic standards to match 2D cad programs. But hopefully Autodesk with catch up and make this process easier.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Fri, Aug 2, 2013 at 11:58:44 AM | Linetype of Dimension line
Oh ... and here is a 2014 dimension:
Fri, Aug 2, 2013 at 12:30:27 PM | WWHub
Avex
Quoting WWHub from 2011-03-28 13:48:13
"Same answer as Mr. Spot's previous answer."
Wow! What a great answer. Easy to have 12000 post just repeating what others say. Also, seems you don't like new people around. Great moderator :D
However, thanks for the answer. I hope that image don't be an override of the dimension element but a modification of the dim style instead. I will check 2014 asap.
Thank you all. Be happy.
Fri, Aug 2, 2013 at 12:37:52 PM | Linetype of Dimension line
#11
Well, an over-ride was never excluded in any of the questions.  Wait - yours was not even a question ... or a helpful answer.  This forum is great because it has a lot of contributors asking quality questions or giving quality answers.  We do occasionally get the visitor that just wants to rant about something like you did.  I guess I should not have 'risen to the bait' but sometimes you have to expose nonsense for what it is.
Revit is NOT CAD ... thanks for that!
Fri, Aug 2, 2013 at 1:23:17 PM | Linetype of Dimension line
#12
Avex
Oh the almighty and smartass moderators (not all of course).
Mine wasn't an answer itself because I rather not to repeat what others say just to increase the amount of posts, number that don't even mean knowledge or helpfulness.
I'm not ranting about things. It is bad to ask for improve tools and features? You just answer "revit its not autocad". Perhaps is it Acad that bad? That's your excuse to say "No, revit can't do that"? Do I have to suit and shape myself to someone's standards just because... I don't know why.
I don't want to be a visitator, I want to stay and learn, but if this is what I get asking things, in my first approach, I will be disappointed soon (I'm already).
It's ok moderator, just keeping replying "Same answer" or "Revit its not ACad" if that is what you call quality.
Fri, Aug 2, 2013 at 1:25:50 PM | Linetype of Dimension line
#13
Avex
Edited on: Fri, Aug 2, 2013 at 1:27:54 PM
Fri, Aug 2, 2013 at 3:09:56 PM | Linetype of Dimension line
#14
Avex
Please moderator, delete this messages. I will delete the "lame" word if was that what pissed you off.
dimension line linetype
Mon, Nov 16, 2020 at 4:25:42 PM
Question about Dimension Linetype
Fri, Oct 19, 2007 at 7:20:43 AM
Handy Linetype
Sun, May 7, 2006 at 8:14:27 AM
Dimension line fixed distance from an Object
Tue, Aug 22, 2017 at 8:18:26 AM
creating a fence linetype?
Wed, Jun 10, 2009 at 6:35:46 AM
Page generation time: 0.3554
