Forums >> Revit Systems >> Technical Support >> Calculated Value
Mon, Dec 13, 2010 at 12:36:16 PM | Calculated Value
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Does anyone know if there is a character limit to Calculated Values in Panel Schedule Templates? I am trying to do an extremely large condition statement but Revit seems to be cutting on my formula half way through....
Mon, Dec 13, 2010 at 12:38:48 PM | Calculated Value
alabaster2513
3.5 Stars: 25 Votes
side note:
Revit help for 2011 blows... it never finds anything. I'm usually all for change but only when it works right
Mon, Dec 13, 2010 at 3:50:23 PM | Calculated Value
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
I was told that it is the same limit as excel...in which case it's like 32,000 and some change.
Never tested to see if it is actually true or not.
I would type what you need in notepad and paste it into the formula and see if it works.
you can see from the image attached that I was able to cram a lot of characters into the formula
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Mon, Dec 13, 2010 at 4:46:58 PM | Calculated Value
alabaster2513
3.5 Stars: 25 Votes
Yeah I have it written in notepad, its long but not that long.
Calculated Values in Room Tags
Wed, Mar 30, 2011 at 4:08:03 PM
Calculated value
Fri, Aug 6, 2010 at 2:17:19 PM
Calculated Values
Mon, Mar 20, 2006 at 12:58:54 AM
Calculated totals of formula in schedule
Fri, Sep 11, 2020 at 7:14:07 AM
How can I create calculated sloping ductwork, with elbows?
Sun, Feb 18, 2018 at 3:12:08 AM
Page generation time: 3.0651
