Forums >> Revit Building >> Technical Support >> Trouble importing AutoCAD survey into an existing buidling model
Mon, Oct 31, 2005 at 4:24:13 PM | Trouble importing AutoCAD survey into an existing buidling model
bigstein
Hello I am an architect new to Revit for about 1 month. I have a building that I started from scratch, setting my first floor grade at 0'-0". According to the actual site survey, this grade is actually 778'-0". When I import the survey, and create a toposurface, the contours come in at their true elevations. Is there a way to get the contour elevations in the toposurface to relate to my existing model? When I try to change my floor elevations to match the survey elevations, my model gets all messed up. Is there any easy trick here, or do I have to rebuild the model using the actual survey elevations? Thanks
Mon, Oct 31, 2005 at 4:26:56 PM | RE: Trouble importing AutoCAD survey into an existing buidling model
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
To move the model up use the relocate project tool in elevation and simply move the whole project up by the required amount.
Mon, Oct 31, 2005 at 5:18:37 PM | RE: Trouble importing AutoCAD survey into an existing buidling model
bigstein
For whatever reason, when I try to 'relocate the project', both the model and the toposurface move up the desired distance, even if I de-select the toposurface. I checked the CAD survey and the contours are at their correct Z coordinates per their elevation. I then tried bringing in the survey and moving it instead of the model. That worked. Isn't there a way to coordinate the Z points in the survey with elevations that you've established with the model? Thanks
Mon, Oct 31, 2005 at 6:24:58 PM | RE: Trouble importing AutoCAD survey into an existing buidling model
eldados
eldados Avatar
4.5 Stars: 8 Votes
TRY GOING TO ELEVATION, PICK THE TOPO AND MOVE UP OR DOWN TO YOUR LOCATION...
Integrator
KarelCAD
Topographical survey
Fri, Dec 4, 2009 at 2:23:19 PM
importing topos for a Site Plan
Sat, May 28, 2005 at 10:20:13 PM
Having trouble import Autocad files into Revit 2010
Tue, Jun 9, 2009 at 8:55:02 AM
topo survey AutoCAD to Revit
Thu, Feb 26, 2009 at 11:45:41 AM
Importing Autocad background - Revit Model to exceede 2 miles across [ 1 2 ]
Sat, Apr 17, 2010 at 7:29:52 PM
20
Page generation time: 0.6277
