Forums >> Revit Building >> Technical Support >> Adding fascia to curved roof.
Mon, Dec 13, 2010 at 8:23:07 AM | Adding fascia to curved roof.
murphyr
Im using Revit 2011 architecture. I have created a roof using the footprint tool. I have added fascia's to all straight roof eaves with no difficulty, however there is one part of the eaves that curves and i cannot get a fascia to fit this section. Has anyone any ideas?
Mon, Dec 13, 2010 at 9:21:59 AM | Adding fascia to curved roof.
A facia is a sweep and works the same.  If your profile is such that it can not successfully follow the path, it will not form.
I have found that if a profile has much definition in the y direction, the sweep profile should be completely "outside" the path it follows.  See attached.  Profile A will work, profile B will not
Can't get fascia heights to match
Thu, May 19, 2011 at 4:57:15 PM
arched roof edge
Fri, Apr 21, 2006 at 4:30:21 PM
How to miter a fascia on a sloped roof?
Fri, Aug 24, 2012 at 7:48:23 AM
Adding PITCH to a Curved/Barrel-Vaulted Roof
Thu, Feb 21, 2008 at 8:21:25 PM
Roof fascia curves in plan and elevation
Sun, Dec 13, 2009 at 1:40:44 PM
Page generation time: 0.5139
