11 Users Online (10 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> hatch22 - my revit hatch generator
Fri, Dec 10, 2010 at 8:36:14 PM | hatch22 - my revit hatch generator
mertens3d
5 Stars: 2 Votes
I've posted the beta version of my free hatch generator (hatch22) on my website.
You can find it here
 Give it a try, let me know if you have any problems.
You can provide me feedback/ suggestions/ etc on my blog
Edited on: Fri, Dec 10, 2010 at 8:36:47 PM
...gregory
http://mertens3d.com
my Revit - Bugs/ Issues/ Requests
Mon, Dec 13, 2010 at 2:30:15 AM | hatch22 - my revit hatch generator
Jeppo
Haven't tried it yet, but if it works as easy as your example on your website, I take my hat off to you.  Nice to see addons which are not chargeable - as these really should be part of the ootb installation of Revit anyway.. (like scheduling door swings, renumbering of tags, etc...hint, hint AutoDesk!)
Thanks,
Lars
Mon, Dec 13, 2010 at 3:09:48 AM | hatch22 - my revit hatch generator
Jeppo
Quick update
Firstly, sorry about mulitple posts - not sure why pc did that...
Tried addin - work brilliantly!  Well done and thanks,
Lars
Mon, Jan 9, 2012 at 7:47:51 AM | hatch22 - my revit hatch generator
eron
i tried this, works perfectly!
thanks very much for this wonderfull job!!
Thu, Mar 22, 2012 at 7:57:07 AM | hatch22 - my revit hatch generator
JLink
Hi,
I love your hatch 22 program, but how can I make a hatch that has an overlapping repeat: (see attached) ?
Thu, Mar 22, 2012 at 1:08:27 PM | hatch22 - my revit hatch generator
mertens3d
5 Stars: 2 Votes
you have to figure out where the pattern repeats cleanly in both the x and y direction.
See the attached image. It looks like it's where I have it marked in red. Base your pattern off of that.
...gregory
...gregory
Thu, Mar 22, 2012 at 1:13:27 PM | hatch22 - my revit hatch generator
mertens3d
5 Stars: 2 Votes
...that is to say the lines you will use in hatch22 will be all the lines that show up within the red boundary I marked above. Y
Your hatch pattern will have to include all of those lines in order to work correctly. (if you want to use hatch22)
It's possibly that you could do a simpler version (like you originally drew).
Once you created a hatch pattern in hatch22 for that you'd have to manually edit it to get the offset you want.
But this would be a pain!
Sure, the .pat file would be smaller, but I don't think Revit would draw it any more efficiently.
In the end you still need all the individual lines...so try it with the bigger pattern.
Make sense?
...gregory
...gregory
Sat, Mar 24, 2012 at 4:37:01 AM | hatch22 - my revit hatch generator
hugh
3.5 Stars: 4 Votes
Here's a pattern for the above tile arangement consisting of four lines:
;%VERSION=3.0
;%UNITS=INCH
*RC22618,DXF Entity Section
;%TYPE=MODEL;-------------------------------------------------------------------------------
;        Pattern written by HatchKit v2.7 Hatch Pattern Editor
;        HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2012.
;        www.cadro.com.au/hatchkit/
0,0,2,4,1,4,-13
90,2,0,4,1,4,-13
-90,0,4,4,1,5,-12
0,-1,4,4,1,5,-12
arranged as is shown in the attached picture taken from a forthcoming HatchKit. To use repetitions constrained to the X and Y axes as shown above you would need to define the 100 or so lines in the 9x9 square shown in the second picture.
To arrange the pattern discussed this thread from JLink
http://www.revitcity.com/forums.php?action=viewthread&thread_id=26963
you would need to define about 440 lines in a 29x29 square as shown in the third picture. HatchKit defines the same pattern in 14 lines.
Really big patterns may overburden Revit by their size and recomputation but I've not seen much difference until linecounts reach the absurd. The effort required to set them up in the first place may be an issue.
Hugh Adamson
www.hatchkit.com.au
Fri, Jun 1, 2012 at 11:33:40 AM | hatch22 - my revit hatch generator
mertens3d
5 Stars: 2 Votes
Hugh,
I see what you're doing now! (rotating the hatch). Very clever.
...gregory
Sat, Jun 2, 2012 at 12:30:47 AM | hatch22 - my revit hatch generator
hugh
3.5 Stars: 4 Votes
The hatch is not rotated.
In HatchKit patterns are formed by arranging the pattern template on a grid. The grid mesh points can be arranged in any two differing directions at any spacing. In the attached picture the red and blue lines indicate the directions and sizes of the arranging grid and the highlighted lines show the pattern template.
Hugh Adamson
www.hatchkit.com.au
Fri, Nov 8, 2013 at 12:41:19 PM | hatch22 - my revit hatch generator
sshneyer
GUYS I NEED A NORMAN BRICK HATCH WITH THE EXACT DIMENSIONS BELOW. CAN SOMEONE HELP ME OUT I SPENT HOURS ON HATCH 22 AND CANT GET IT TO WORK!!
THANK YOU!
Fri, Nov 8, 2013 at 1:02:52 PM | hatch22 - my revit hatch generator
Do you really want mortar joints?  Typically that is too intense for most views.
Fri, Nov 8, 2013 at 2:03:30 PM | hatch22 - my revit hatch generator
#13
mertens3d
5 Stars: 2 Votes
sshneyer,
What problems were you having with hatch22? Can you be specific?
Did you look at the samples file? That will probably help as it has some brick patterns in it.
http://mertens3d.com/tools/revit/2012/hatch22-2012/hatch22-2012-examples.php
...gregory
Fri, Nov 8, 2013 at 7:23:37 PM | hatch22 - my revit hatch generator
#14
hugh
3.5 Stars: 4 Votes
Here you go:
;        Written by HatchKit 2013 Hatch Pattern Editor
;        HatchKit 2013 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2013
;        www.hatchkit.com.au/
;%UNITS=INCH
;%VERSION=3.0
*NormanBrick1-3RunningBond,horizontal 11.375"x2.375" bond=1/3
;%TYPE=MODEL
90,0,0,2.75,-3.91666666667,2.375,-5.875
0,0,2.375,-3.91666666667,-2.75,11.375,-0.375
-90,11.375,2.375,2.75,-3.91666666667,2.375,-5.875
180,11.375,0,3.91666666667,2.75,11.375,-0.375
Hope this helps.
Hugh Adamson
www.hatchkit.com.au
Fri, Nov 8, 2013 at 7:40:37 PM | hatch22 - my revit hatch generator
#15
hugh
3.5 Stars: 4 Votes
Whoops, had hair in my eyes, this is the actual bond pattern requested
;%VERSION=3.0
;%UNITS=INCH
*NORMANBRICK1-3RUNNINGBOND,horizontal 11.375"x2.375" bond=1/3
;%TYPE=MODEL
;        Pattern written by HatchKit 2013 Hatch Pattern Editor
;        HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2013.
-90,15.295,5.123,0,11.75,2.375,-3.125
90,3.9199,2.748,0,11.75,2.375,-3.125
0,3.9199,5.123,0,5.5,11.375,-0.375
180,15.295,2.748,0,5.5,11.375,-0.375
-90,11.375,2.375,0,11.75,2.375,-3.125
90,0,0,0,11.75,2.375,-3.125
0,0,2.375,0,5.5,11.375,-0.375
180,11.375,0,0,5.5,11.375,-0.375
Hugh Adamson
www.hatchkit.com.au
Hatch Pattern generator
Thu, Oct 6, 2005 at 1:49:14 AM
Ceiling grid hatch
Tue, Apr 30, 2013 at 2:23:08 PM
Revit Text Generator
Fri, Feb 4, 2011 at 1:33:36 PM
Custom Hatch Generator
Tue, Mar 1, 2016 at 1:42:04 PM
12
Looking for Revit Structure Extension Text Generator
Mon, Jan 24, 2011 at 2:11:22 PM
Page generation time: 5.0796
