23 Users Online (21 Members):
Forums >> Community >> The Studio >> copy new level
26 Posts No Rating |
i am new to revit, ex ArchiCAD
how to copy a level to next level? if they are all identical.
how to adjust the stair handrail when you draw stair with boundary or run? you do not have to do adjust after you created?
why8888
Welcome to the wonderful world of revit.
1. Select element on one level, copy to clipboard, paste aligned by level and pick all the levels that you wish to paste the elements...
2. Select the handrail and edit the sketch or change its type if need be. Of course you can edit things after they are created.
HTH.
regarding stairs, you can also change your stair to be a multi level stair, if the height between levels is the same, you can run it all the way up.
just go to stair properties and tick multy level and the desire level...
Can't copy furniture group to different level view |
Thu, Jun 7, 2018 at 10:43:54 AM
copy groups from level to level |
Fri, Feb 5, 2010 at 7:55:06 AM
Copy Dimensions |
Fri, Oct 10, 2008 at 7:26:58 AM
Aligning grids the same in each level? |
Fri, Sep 23, 2005 at 11:13:39 PM
Revit Architecture 2012 - Copy/Mirror Changes Component levels |
Wed, Feb 6, 2013 at 2:01:45 PM
