Forums >> Community >> Newbies >> Paint Walls
Fri, Dec 10, 2010 at 10:31:41 AM | Paint Walls
maddy2210
Hello everyone,
Could you please tell me how to paint my wall? I know how to paint it using "paint command under modify panel", but here's the actual problem is.... it gives me option of applying it by materials only....
I have few 10' high walls which runs at my ceiling height, then I have few 15' high walls that runs up to my deck...both of them have same material like... both of then are 4-7/8" interior partition wall with one layer of gypsum board on each side...the only difference is in their heights... one is 10' and another one is 15' high...
So when I apply paint by material and I select gypsum board... both of my walls are of same color.... but what I want is I wanna make my 15' walls looks different then my 10' walls..... Any suggestions????
Fri, Dec 10, 2010 at 12:02:23 PM | Paint Walls
If the walls are defined as gyp bd, they will both be the same.  Use a different material.  Create a new material paint 1 and apply that to one wall.
Remove Paint from Walls
Wed, Feb 9, 2011 at 1:33:46 PM
Changing Wall Paint color
Sun, Feb 7, 2010 at 7:02:40 PM
How to apply paint to walls/choose a colour?? (Revit Architecture)
Mon, Nov 14, 2016 at 10:38:53 AM
Walls - Paint Layer
Tue, Feb 12, 2013 at 7:59:06 AM
Paint Help
Thu, May 23, 2013 at 6:19:10 AM
Page generation time: 1.9444
