Forums >> Revit Systems >> Technical Support >> Help with a duct family -trying to prevent resizing by dragging or limiting drag
Thu, Dec 9, 2010 at 4:19:14 PM | Help with a duct family -trying to prevent resizing by dragging or limiting drag
jcrocco
3 Stars: 1 Votes
I am in process of trying to make a duct family so we can try to piece togther a duct system so it can be scheduled and used as shop drawings.  I have asked about this a few times on this site, and no one seems to be able to answer, so I guess I gotta do it myself. . . LOL.  Smile
Anyway, I made a duct family with connectors on either end and the ability to change length, width, and thickness. EASY, actually.
What I now am trying to do is to prevent a duct family from being able to be dragged and resized.  I want to be able to resize it within the instance properties, but not to be able to drag and change it with the curser.  Is this possible?
Another idea, aybe even a better one, might be to allow it to be able to drag and resize the length only, but somehow limit the length to be a maximum of 59".  This would solve some other problems, but not sure if this limitation can be built into the family.  I would still want the height and width non draggable however.
I have attached the file if anyone would like to take a look.  Any help would be appreciated.
Thu, Dec 9, 2010 at 6:23:02 PM | Help with a duct family -trying to prevent resizing by dragging or limiting drag
It sounds like (sounds best) that duct size would be type parameters and length would be instance.
You can not lock the instance but I don't see a reason to do that.  You might be able to create a formula that will work for your max... something like actual_length=If (length>59",59",length)... you work on the syntax.  << Don't have Revit here to test this.
Fri, Dec 10, 2010 at 8:28:18 AM | Help with a duct family -trying to prevent resizing by dragging or limiting drag
jcrocco
3 Stars: 1 Votes
I will work on that, thank you.
Fri, Dec 10, 2010 at 9:17:39 AM | Help with a duct family -trying to prevent resizing by dragging or limiting drag
jcrocco
3 Stars: 1 Votes
I got a formula to work.  The issue I still have is the shape handle will still drag the duct as long as I want it.  If I go into the properties, and change the length to 10', it will default to the 4'11" dimension per the formula, but the shape handle ignores the fornmula.
How can I prevent the shape handles from exceeding the max length, or can I disable the shape handles altogether?
Fri, Dec 10, 2010 at 9:33:06 AM | Help with a duct family -trying to prevent resizing by dragging or limiting drag
TKennedy
4 Stars: 8 Votes
Setting the Ref Planes to "not a reference" should get rid of the grips.
Fri, Dec 10, 2010 at 9:51:10 AM | Help with a duct family -trying to prevent resizing by dragging or limiting drag
If the family is sized correctly, why do you care about the shape handle?  The family is correct.
Fri, Dec 10, 2010 at 10:20:11 AM | Help with a duct family -trying to prevent resizing by dragging or limiting drag
jcrocco
3 Stars: 1 Votes
Fri, Dec 10, 2010 at 10:23:31 AM | Help with a duct family -trying to prevent resizing by dragging or limiting drag
jcrocco
3 Stars: 1 Votes
because the shape handle changes the length of the duct.  i want to specify the duct length, and not have it change by dragging the shape handle.  Also, dragging the shape handle was overiding the limitation of the max length.  I made the ref plans not a ref and that worked.
Eccentric Duct Fittings?
Thu, Dec 15, 2011 at 10:58:31 AM
Help - Duct Callouts are relocating on drawing
Fri, Mar 27, 2009 at 10:36:57 AM
Duct accessories family do not break into
Tue, Nov 5, 2019 at 8:55:37 AM
Duct Fitting Issue
Tue, Apr 1, 2014 at 1:16:35 PM
Family Editor - Duct Connector
Mon, Jun 16, 2014 at 1:52:01 PM
Page generation time: 1.9154
