Forums >> Workflow & Implementation >> Hardware >> Adding monitor freezes Revit
Thu, Dec 9, 2010 at 8:46:03 AM | Adding monitor freezes Revit
frankwright
On a 64-bit laptop with Vista that was running 2010 just fine, I added a monitor for additional display space.  It seemed to be working fine until Revit started "freezing" as if trapped in an edit mode, not allowing me to even save to get out of it.  I was able to zoom in and out with the scroll wheel, and even open new views, but nothing was selectable and no tools were operating.  Disconnecting the monitor resolved the problem.  Is this a video card issue?  I was connected thru the VGA port and not HDMI, so could that be part of the problem?  Whatever it is, it seems contained within Revit. Thanks for any advice.
Thu, Dec 9, 2010 at 12:20:42 PM | Adding monitor freezes Revit
gdoherty0102
3 Stars: 2 Votes
You said that it freezes in edit mode....
Does revit work fine if you are just working out side of an edit/group mode?  If this is so, this is because your buttons to finish the group, sketch, etc have became undocted.  Go to "View" - "User Interface" - Check "Recent Files" - Click "Modify" - "User Interface" - Uncheck "Recent Files" and your buttons will come back.   My appoligies if this is not the issue you explained.
Material Change, Revit freezes
Thu, Jan 12, 2012 at 4:44:25 PM
Revit freezes when opening sheet views
Fri, May 11, 2012 at 5:23:01 PM
Revit freezes when I do a 'Save As'???? Need help urgently!
Fri, Aug 9, 2013 at 10:53:11 AM
Worksharing Monitor
Fri, Jun 6, 2008 at 1:27:29 PM
1440p or 120hz monitor for Revit
Sat, Aug 24, 2013 at 6:11:13 PM
Page generation time: 1.4595
