16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Cannot cut below grade sections with any depth after topography placed
Hi, When I insert topography into Revit 2010, the portions of my building that are below grade cannot produce section cuts with any depth. As in, if I cut through a stairwell that runs from the basements up through to the roof, the floor above grade show the rails in the distance that I allowed in the section cut view distance, but once the building goes below the grade line, all distant object vanish, and I am left with only the objects that the cut line itself is passing through. This goes away if I delete or hide the topo. Based on assumption, I think maybe the topo is considering everything below the grade to be solid earth, and so it is showing me that beyond the section line is solid, non-transparent earth. Is there a way to either set the topo to only show me the surface grade line in section view? I can hide the earth hatch easily enough in Visibility Graphics or even in the material setting, but I think Revit still acknowledges that there is non-transparent Earth there. How can I create a surface topo without any earth mass below it?Thanks all!-Joe I edited this post to change the text size to a readable font. -wwhub
Edited on: Wed, Dec 8, 2010 at 3:19:24 PM
AECOM - Have we swallowed your firm into our collective yet? Resistance is futile. |
Yes, Revit will not automatically make room for your structure below grade. You have to cut the topography or use a pad. You can read about PADS in your HELP or search the forums - PAD.
This issue was solved! Thanks again WWHub!
http://www.revitcity.com/forums.php?action=viewthread&thread_id=24464
linked file visability and cut depth [ 1 2 ] |
Thu, Jul 13, 2017 at 3:23:18 AM
16
Using topography to cut an object |
Thu, Jun 1, 2017 at 6:52:01 AM
Revit Topography schedule - several issues! |
Mon, Jul 14, 2014 at 8:59:00 AM
CUT AND FILL - PADS WHICH DO NOT SHOW C&F VOLUME ON A SCHEDULE |
Tue, Feb 13, 2018 at 4:37:06 AM
Placed Sections on Sheet, Plan Cut Lines Disappeared, But the Sections Remain |
Sun, Dec 2, 2012 at 7:34:52 PM
