Forums >> Community >> Newbies >> pdf program
Tue, Dec 7, 2010 at 7:53:22 PM | pdf program
lbr549
What is the best/easiest pdf writer to use with both Revit and AutoCAD?  Any thoughts.  I have acroplot and have used it for years, but I have a new computer without a pdf writer, so thought I would ask before I purchase acroplot agian.....
Tue, Dec 7, 2010 at 9:51:04 PM | pdf program
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Try this one: CutePDF
Tue, Jan 11, 2011 at 2:15:22 PM | pdf program
lbr549
OK, i've tried CutePDF and it works, but only one at a time, no batch feature and seems reallllllly slow.  Has anyone had any experience with Bluebeam?  I don't mind paying for a good program if it works.
Tue, Jan 11, 2011 at 3:36:21 PM | pdf program
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
PDFCreator, makes other file types as well.
Tue, Jan 11, 2011 at 3:42:19 PM | pdf program
You can batch print to cute... all in one file or seperate files.  Only problem is that you have to name each file but you can batch.  And mine is pletty fast enough.  I export my schedule so that I can just copy paste in my names and I can barely keep up.
Tue, Jan 11, 2011 at 4:59:16 PM | pdf program
pchan
pchan Avatar
5 Stars: 5 Votes
I have used BlueBeam to batchplot pdf in Revit in the past and it works pretty much like others. but you don' t have to name each file every time.
or you can use DWF as a default printer which I prefer it to PDF.
Tue, Jan 11, 2011 at 11:07:03 PM | pdf program
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
try Xrev Transmit, which goes to beta next week.
http://www.xrev.com.au/products/Xrev-Transmit
Regards,
Chris.
Thu, Jan 13, 2011 at 11:26:19 AM | pdf program
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
PDFCreator does batch plots and is FREE
Thu, Jan 20, 2011 at 5:37:46 AM | pdf program
RevitZone
I use "PrimoPDF". It's free and very good.
Cheers,
Ian
www.RevitZone.com    News / Articles / Tutorials / Forums / Resources
Thu, Jan 20, 2011 at 1:38:35 PM | Mr Spot
TKennedy
4 Stars: 8 Votes
Quoting Mr Spot from 2011-01-11 23:07:03
Hmm. That's something I'm going to watch closely.
Thu, Mar 31, 2011 at 8:57:50 PM | pdf program
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This will be released for sale in the next couple of hours.  Not free, but it does do more than just creating a PDF...
Sorry, now switching out of marketing mode...
Regards,
Chris.
Crashing While Converting to a PDF
Wed, Jan 5, 2022 at 9:17:01 AM
PDF Quality?
Fri, Dec 9, 2011 at 12:16:09 PM
.txt Conversion to .pdf
Wed, Feb 8, 2012 at 3:43:28 AM
Revit PDF Drivers
Fri, Sep 16, 2016 at 4:05:46 PM
Viewport titles moving
Mon, Nov 10, 2008 at 10:16:48 AM
Page generation time: 0.1710
