15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Newly drawn model lines not showing up in Floor Plan (revit 2010)
35 Posts No Rating |
I have existing model lines in the plan that I can see fine, but if I try to draw new ones they do not show up. There is no plan region that is in the way. I also can stretch a existing line into the area were I was trying to draw the new line and it is visible in that area.
Edited on: Tue, Dec 7, 2010 at 12:41:44 PM
20 Posts No Rating |
THE ONLY THING I COULD THINK OF THAT WOULD DO THAT WOULD BE THE CROP VIEW/ CROP REGION/ ANNOTATION CROP. CAN YOU DRAW A LINE IN THE AREA THAT YOU CAN SEE AND THEN MOVE THE LINE TO THE AREA WHICH IT WON'T SHOW UP WHEN YOU DRAW IT?
Check your work plane and view range, you may be inadvertently drawing your new lines higher or lower than you think.
Thanks for the input. I just figured it out. My floor system was 1.5" into the 2nd. level.
Ceiling Model Lines Showing up on Floor Plan |
Tue, Dec 13, 2011 at 6:04:04 AM
Model line types not showing correctly in one floor plan |
Wed, Jun 22, 2011 at 11:20:28 AM
Faint lines showing from ground floor on first floor |
Sat, Mar 10, 2012 at 4:40:33 PM
Model lines not showing up on slab surface |
Sun, May 1, 2016 at 8:30:20 AM
Light switches not showing on floor plan |
Fri, Apr 29, 2011 at 2:14:19 PM
