Forums >> Revit Building >> Technical Support >> Import DWG problem with size
Mon, Dec 6, 2010 at 3:20:14 PM | Import DWG problem with size
WestCAD1
I have a dwg file that is in millimetres. When I try to import I get message.....cannot import because it would create revit model that is larger than 2 miles across. I have import units set to auto detect, however when I change these to meters, I get the same message. Any assistance would be greatly appreciated.
Mon, Dec 6, 2010 at 5:02:34 PM | Import DWG problem with size
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Is this a survey? may be due to origin distance from actual object
Mon, Dec 6, 2010 at 7:33:32 PM | Import DWG problem with size
WestCAD1
Thank you for your assistance. The file was a survey created by third party and on closer inspection the z co-ordinates were all over the shop. I fixed these and the file imported no problems.
Revit 2010 Dwg. Import problem
Thu, Sep 2, 2010 at 1:52:03 AM
Can't import dwg or dxf to RS2008
Wed, May 30, 2007 at 10:36:07 PM
.dwg import problem
Tue, Sep 6, 2011 at 7:48:54 AM
dwg importing problem
Wed, May 28, 2008 at 8:52:30 AM
Import DWG in Family - Problem!!!
Fri, Sep 28, 2007 at 2:31:36 PM
Page generation time: 1.6055
