22 Users Online (20 Members):
Forums >> Revit Structure >> Technical Support >> Nested void geometry doesn't cut host solid
2 Posts No Rating |
Im trying to create a family with a parametric array of void geometry, in order to get the array parameters working correctly it needs to be nested, however when it is loaded into the host family it will not cut the solid geometry. i can't seem to figure out what im doing wrong, can someone help please?
Before you finish any void, you have to define the host that it cuts. How did you create the void? Perhaps you should use a face hosted void where the void cuts the host face.
2 Posts No Rating |
Tried that too, doesnt work. ive tried a lot of different options like this but just can't make it work. Could it be the case that voids in nested families just do not cut geometry in host families that is not a system family?
What are you trying to cut?
Stopher, Nested families are capable of cutting geometry within a host family, as long as the nested family is face based. I believe the standard families (non-face based) will not allow you to cut a host with a nested void. Try creating your parametric void array as a face based generic model family.
Use Nested Void Family to Cut Host? |
Sat, May 28, 2011 at 10:39:48 AM
void form and cuttng void form |
Fri, Jul 9, 2010 at 12:39:02 PM
Void Masses |
Fri, Oct 3, 2008 at 4:11:06 PM
Void extrusion wont cut mass |
Wed, Nov 21, 2007 at 11:27:01 PM
VOID FORM says there is no geometry to cut.... [ 1 2 ] |
Wed, Dec 17, 2008 at 12:52:27 PM
19
