Forums >> Revit Building >> Technical Support >> RAC 2011 is there a way to change all level lines to 2d or 3d at once?
Mon, Dec 6, 2010 at 1:50:07 AM | RAC 2011 is there a way to change all level lines to 2d or 3d at once?
rudyard
1 Stars: 1 Votes
In elevation and section when adjusting my foor levels lines, in a multistory building it is a royal pain up the butt to have to select each level and press the little 2d icon on both sides to control them in a view specific manner.
 Surely there is a way to change them all to 2d or 3d in one click rather than indvidually selecting each one?
Mon, Dec 6, 2010 at 7:50:31 AM | RAC 2011 is there a way to change all level lines to 2d or 3d at once?
Read these topics in your HELP:  Propagating 2D Datum Extents  and    Maximizing 3D Model Extents
Mon, Dec 6, 2010 at 7:57:35 PM | RAC 2011 is there a way to change all level lines to 2d or 3d at once?
rudyard
1 Stars: 1 Votes
thanks but thats not what im after.  propogate extents only matches those already in 2d, dragging the level lines is no issues since they all move together when in 3d or 2d, the annoyance is to have to individually click each level line and click the 2d/3d icon on each side.
 In our current 13 storey building with floor and ceiling lines this is 26 clicks per elevation and section.  I was hoping for a 'change all to 2d' button which would make sense.
Floor finish in relation to level assigned
Fri, Jun 17, 2011 at 2:10:03 PM
What is this new symbol when creating a floor in RAC 2011?
Fri, Feb 4, 2011 at 11:53:03 PM
Level lines on sheets...
Mon, May 12, 2008 at 10:26:04 AM
Phasing: problem with new doors in existing wall joint lines
Mon, Sep 19, 2011 at 4:32:08 PM
How do you hide different material joint lines?
Thu, Sep 15, 2011 at 6:53:41 AM
Page generation time: 0.7535
