Forums >> Revit Building >> Technical Support >> Floor Sketch mode
Fri, Dec 3, 2010 at 11:57:07 AM | Floor Sketch mode
Abill
When drawing a floor in sketch mode two short lines appear near the center of the first line that you place. What are they for?  Thanks
Fri, Dec 3, 2010 at 12:03:00 PM | Floor Sketch mode
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Indicates Floor Span Direction. There is also a tool to switch that direction on the ribbon.
Fri, Dec 3, 2010 at 3:46:30 PM | Floor Sketch mode
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
You'll see the same thing happen when you model beam systems.  In beam systems the purpose is most evident -- this is the direction that the beams will run in.
Question about sketch Mode
Thu, Jan 17, 2013 at 6:34:56 PM
RST 2012 RIBBON IS ACTING CRAZY . . . while in sketch mode
Wed, Apr 11, 2012 at 3:36:06 PM
Revit won't (Grey/Halftone/Fade) during any Sketch/Edit/Modify mode
Tue, Feb 27, 2018 at 11:18:53 AM
Filled Region Sketch Mode
Tue, Nov 17, 2015 at 1:28:34 PM
Split Face Sketch on Floor Completes then Displays Error: Line is Too Short
Wed, May 22, 2013 at 3:12:37 PM
Page generation time: 1.3653
