Forums >> Revit Building >> Technical Support >> modifying system family
Sun, Oct 30, 2005 at 4:58:01 PM | modifying system family
nika777
is it possible? where can I find those files and how can I modify them? ( I need to make a special window' basing in exisitng, but with a static lower glass and exactly same frames. sos!
Sun, Oct 30, 2005 at 6:30:23 PM | RE: modifying system family
eldados
eldados Avatar
4.5 Stars: 8 Votes
all your families are in the library, be it the metric or imperial depends on what you installed. you can either go to the library and open it or if it's in your drawings you can right click and go to edit family.
Integrator
KarelCAD
Modifying a curtain panel system to add louvers
Thu, May 22, 2014 at 2:53:35 PM
Modifying Default Family Templates
Mon, Apr 26, 2010 at 2:20:23 PM
Modifying Families
Tue, Mar 10, 2009 at 9:55:47 PM
13
New System Family
Wed, Jan 25, 2012 at 9:27:12 AM
System Family Names
Wed, Sep 9, 2009 at 10:32:42 AM
Page generation time: 1.6634
