12 Users Online (10 Members):
Forums >> Revit Structure >> Technical Support >> Can't apply parameter to array number
I am trying to array rebar in a footing, but I can't apply a parameter to control the number of bars in the array. When I create the array and the right-click on the array number, "edit label" is grayed out and I can't click it. Am I missing something? How do I apply the parameter to control the array number? Thanks
I think you can only add a lable to an array in a family. Secondly, why are you using array for rebar? The only time that we use array for rebar is when the bars stay perpendicular on a radius. You should just be able to set the max spacing, number of bars, or the spacing and number of bars...
Are you trying to create a footing family or using the footing tool in the project? REVIT Structure takes care of adding rebar to footings, slabs, columns etc without doing a manual array. The attached image shows what was capable in REVIT Structure 2008.
I was trying to get the array to read a parameter from a footing family that would control the number of bars in the footing. Ideally this would be done in the footing family itself, but I thought I read somewhere that it is not possible to place rebar in the family editor environment and because of that I was attempting this in the project environment. I know that when you place a single bar in a concrete element you can specify whether it is single, or the number of bars, numbers of bars with spacing, etc. but this method will not update based on a parameter correct? Otherwise, it would have to be updated for each footing instance. dgcad - are you referring to the reinforcement extensions?
Array Distance Parameter |
Thu, Apr 11, 2019 at 8:53:57 AM
Numerate 'Sheet Number' parameter for match line family |
Mon, Apr 28, 2014 at 10:17:51 AM
Array Parameter within Family |
Thu, Aug 7, 2014 at 8:25:09 AM
Centering an Array Parameter within a Family (Wall Based) |
Fri, May 4, 2012 at 5:06:22 PM
Array Parameter |
Tue, Apr 27, 2010 at 11:18:05 AM
