Forums >> Revit Structure >> Tips & Tricks >> How to quickly calculate area like in autocad?
Thu, Dec 2, 2010 at 4:42:09 PM | How to quickly calculate area like in autocad?
rkowalski
Let's say I am in plan sketching phase and have a non-rectangular shape and I want to know its area just to relate it to area allowed in building standards?
Thu, Dec 2, 2010 at 7:47:52 PM | How to quickly calculate area like in autocad?
Dynamite
Dynamite Avatar
4.5 Stars: 35 Votes
If you havent found a solution yet...., Try the following. Use the floor tool to trace the outline of your plan. click finish. right click on the properties button of the floor and it should list the AREA, PERIMETER and VOLUME. Good luck!
Thu, Dec 2, 2010 at 9:31:55 PM | How to quickly calculate area like in autocad?
dcad79
If this applies to AutoCad, my best advice is to trace the room with a polyline. Then left click on the polyline,right click click --then properties and look for "area". Hope this works out for you.
Fri, Dec 3, 2010 at 12:16:04 AM | How to quickly calculate area like in autocad?
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
A filled region can solve that too + its filled. Duh. Check the area in properties too.
Fri, Dec 3, 2010 at 2:55:48 AM | How to quickly calculate area like in autocad?
4 Stars: 205 Votes
Maybe this can help you too: http://revitclinic.typepad.com/my_weblog/2010/10/quick-tip-revit-model-line-total-length.html
Fri, Dec 3, 2010 at 9:18:01 AM | How to quickly calculate area like in autocad?
gdoherty0102
3 Stars: 2 Votes
What my old firm put together was a few different masses with labels...they would then place them and pretty much do a bubble diagram with it, and the masses allow you to calculate the areas as well.  Might be something to consider...
Fri, Dec 3, 2010 at 10:50:04 AM | How to quickly calculate area like in autocad?
lunchtrayrider
3.5 Stars: 7 Votes
+1 to filled region.
I like scooters. and motorcycles.
How can I calculate the area of a curtain system
Thu, Oct 30, 2014 at 9:17:00 AM
Calculate Demolition
Fri, May 8, 2015 at 3:56:11 PM
Revit 2013 Material Takeoff area calculation
Wed, Jun 11, 2014 at 10:28:46 AM
How to add wall area in schedule per wall
Thu, Nov 19, 2009 at 1:10:27 PM
Room Tags That Calculate [ 1 2 ]
Mon, Feb 17, 2014 at 3:28:45 PM
22
Page generation time: 2.7424
