12 Users Online (10 Members):
Forums >> Revit Structure >> Technical Support >> Changing the shape of joints between wall panels?
1 Posts No Rating |
So I create wall panels by drawing the walls and using the "Split with Gap" tool, and this will work great with standard tilt-wall jobs, but we also do work for this precast concrete wall panel manufacturer who normally uses a shiplap joint between panels (see attached image), is there a way to change the footprint shape of the wall panel? (While still being able to function, be analyzed, etc. like a wall.)
Why can't this just be a detail element and added at larger scale views where necessary?
Curtain wall panels changing materials when pinned |
Fri, Feb 26, 2010 at 8:46:05 AM
Curtain wall panels not trimming correctly against mullions |
Thu, Dec 10, 2009 at 5:49:55 PM
vertical joints in hosted wall sweep? |
Mon, Aug 13, 2007 at 3:37:15 PM
Wall Corners and Joints |
Thu, May 9, 2013 at 2:50:52 PM
Modular Wall Panels |
Sun, Oct 9, 2011 at 8:29:52 PM
