Forums >> Revit Building >> Technical Support >> door in pattern curtain wall
Wed, Dec 1, 2010 at 3:02:55 PM | door in pattern curtain wall
andy768
I'm designing a fire station and am trying to put doors in a custom curtain wall i made through massing and patterns. I have tried approaching it from various ways but all prove unsuccessful, can anyone please help me figure out how to do this? thanks
Wed, Dec 1, 2010 at 3:23:26 PM | door in pattern curtain wall
gdoherty0102
3 Stars: 2 Votes
If I am incorrect on your methods I appoligize.
This is a farily common misconseption for those new to Revit.  A curtain wall/store front door is not a door, it is a curtain wall panel.  You just need to tab to the curtain wall panel you would like to be a door and then select which door you would like it to be.
Wed, Dec 1, 2010 at 3:38:12 PM | door in pattern curtain wall
andy768
I cant upload the file, its over 2 mb. here are some images of what im working with.
u can see how i approached the door issue on the concrete wall (vs curtain wall that i am trying to do now)
I followed the autodesk student expert tutorials and made a pattern curtain wall by
making a form out of lines
then dividing the form's surface along vertical or v grid
drew lines and used intersects for u grid
applied curtain panel as pattern
for creating the openings for door only way i could think of was void form so i went back and deleted  pattern and made the void openings but now cant get panels to fit... PLEASE HELP
Wed, Dec 1, 2010 at 3:41:14 PM | door in pattern curtain wall
Please read this in your HELP :> Adding Doors to Curtain Walls
A door can never be hosted in a void....
Wed, Dec 1, 2010 at 3:57:07 PM | door in pattern curtain wall
andy768
I think that since its a pattern curtain wall, there is no option for doors when i select a panel, only other panels such as solid or glazed. Not sure how to post the file since its 5000kb
Wed, Dec 1, 2010 at 3:58:22 PM | door in pattern curtain wall
andy768
I was going to try and put a normal wall in the void and put the door on that
Wed, Dec 1, 2010 at 6:55:51 PM | door in pattern curtain wall
andy768
I can't figure it out
Wed, Dec 1, 2010 at 6:56:35 PM | door in pattern curtain wall
andy768
does anyone know how to make an opening in the curtain wall FROM PATTERN?
Thu, Dec 2, 2010 at 8:07:20 AM | door in pattern curtain wall
If you are expecting to put a door in a sloping curtain wall or in a panel with sloping side mullions, you can't really build it so you probably can't model it unless you build something in -place.  However, a curtain wall door does work in a curtain system placed on a mass by face.
Curtain Wall Panel to Curtain Wall Door
curtain wall door
Tue, Jan 31, 2006 at 1:36:58 AM
Curtain wall door frame
Mon, Mar 2, 2015 at 11:37:33 AM
How to place Curtain/Glass Door for Curtain Wall for Revit Architecture 2012
Thu, Jul 7, 2011 at 4:27:10 PM
Retaining Curtain Wall Door Scheduling Data
Thu, Jan 8, 2015 at 2:47:08 PM
Page generation time: 0.7289
