Forums >> General Discussion >> Revit Project Management >> How Can I remove Double Obgects
Tue, Nov 30, 2010 at 11:56:52 PM | How Can I remove Double Obgects
mhbn4
2.5 Stars: 4 Votes
I Have some Wall,Lines,Objects.... But some of them Are Exactly Over each Others And I want to remove Doubled objects How can I resolve Them?
Wed, Dec 1, 2010 at 12:32:26 AM | How Can I remove Double Obgects
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
simply press tab button while the mouse button is near to that objects, and when you select the elemeent you need to delete just delete it.
But, as example, you only want to delete the lines, select all, click on the filter button ( you can google it "filter button revit"Winking and delete that lines.
The duplicated 3d object must have an error, check the error listed on the exclamation sign down right of the screen.
How to make double or tripple Andersen double-hung windows
Sun, Jan 11, 2009 at 12:38:51 PM
another double pitch roof question!
Thu, Jun 14, 2007 at 10:42:50 AM
Andersen double hung windows
Sun, Jan 18, 2009 at 4:45:24 PM
MOUSE TOOLTIP OPTION
Mon, Nov 17, 2014 at 8:10:41 AM
curtain walls make like partition walls
Sat, Oct 25, 2008 at 4:00:59 AM
Page generation time: 1.3573
